I'm pretty new to tubes but i just got my Russian tubes and its working much much better with distorsion and noise. Money well spent IMO.I am pretty new to the audio world and decided to dip my toes into the tube world and bought the Little Bear T10 V2.2 off amazon. My current setup is Project Debut III (Ortofon OM5e cartridge) -> Little Bear T10 V2.2 -> Crown XLS1002 AMP (.775V input sensitivity) -> Klipsch Icon wf-34 speakers.
The issue I am having is the mid range is very distorted. I first listened to Miles Davis' Some Kind of Blue and the highs sounded great, but everything else sounded distorted. I initially chalked this up to the tubes being new and needed time to burn in, but after a few days of listening there has been no change. My buddy who has some experience with tube guitar amps recommended playing something more modern with a lot more mid range to try and diagnose what is going on. We played Journey's Don't Stop Believing and it sounded terrible. I double checked to make sure I wired everything correctly and everything was switched to 6N2. He chalked it up to bad tubes. According to the specs on my Crown Amp and the Little Bear the sensitivities should be compatible.
Do you guys think its the tubes? Or is there a larger issue at hand? I am very new to this and I don't want to spend $60 on new tubes for a $120 pre-amp. Any help you guys can provide would be greatly appreciated. Thank you.
tried swaping the tubes around and see if it makes it sound different?
test it with your friends tubes if you can do it before the time runs out for return. It should sound alright even with Chinese tubes. even with the wrong resistance etc for your cartridge it should just be sounding thin not distorted.Thank you for the reply. I did move the tubes around in a couple different configurations and did not notice a difference. I am trying to borrow some 12ax7's from my buddy's guitar amp to see if swapping out tube clears up the issue. From what I have read online the amp should sound half way decent with the Chinese tubes, but since it sounds so bad with those Chinese tubes I am concerned there is a large problem at hand. Any other suggestions? I am half way tempted to return the unit while I still can...
Left the amp on a bit last night as I was listening to some music at dinner time. When I went to shut amp down I noticed there was an audible hum from the amp, not speaker hum in the audio path, but the actual unit itself was vibrating.
Questions:
1. Could this be contributing to my audio hum issue?
2. What could be causing this?
Hi, everybody. I here for the first time. And I badly know English. But I want to share the experience with you uses of LB. I did different experiments to improve a ratio signal \noise but then left everything as was in the original scheme. I changed only polarity of power supply of heaters. I cut a board to divide the power unit and the amplifier. Also I replaced sockets of tubes with sockets with shields. Here is how it looks now. The sound became much better. Noise disappeared. And already almost everything is pleasant to me
