Thank you Jim, I've put a lot of work into the cables I make.
Ok, here's the update for the evening. First of all, as requested, I've taken some pictures. For those not familiar with the I+, the op-amp that's "rolled" is in the center of the circuit surrounded by four capacitors. The little thing in my hand in the other picture is one of the shunts, or jumpers, used to make the I+ compatible with various families of tubes. And finally, a picture of the Telefunken tubes I tried tonight, because many of us love to look at and handle tubes.
I spent quite a few hours listening to the I+ tonight. After a couple hours I switched from the stock (upgrade) WE408A tubes to the CV4010 Telefunkens. My one complaint about the I+ so far is that it's sort of a pain to take a apart, at least mine is. The holes in the bottom half of the chassis don't line up perfectly with the rest of it, which makes it difficult to get the screws back in when you're done. It's also a little tougher than I thought to safely remove an op-amp, and even more difficult to put one back in the socket. Overall, perhaps I'm exaggerating, and I'll survive, in any case..
To be honest I'm not sure if I hear as big a difference between the tube types as I did with the op-amps. There was a difference though - the Telefunkens sounded "bigger," with a wider soundstage, and perhaps a tad more lush than the WE408A. I could be imagining this, but it seems there's a little less dynamic impact now. Because the Telefunkens and the Mullards I have are from the same family of tubes, I was able to quickly install the Mullards a little while ago. Again, no dramatic changes, still a wide, three-dimensional sound like the Telefunkens, a little warm and very smooth.
They both sound good, but I'm reserving any final judgments as these really need to be left on the Frybaby for a while to break in. I think I'll start with the Mullard since it's already in there. Jim was kind enough to sell me a pair of Tung Sol 408's, those should be here soon and they're supposed to be quite good.
I'm really enjoying the I+. It sounds much better now than it did out of the box - and even then it sounded nice. For the money its performance is very impressive.
