33&athird
Turn on & Tune in
Very cool, I really hope to get one of these in a week, if not...well, eventually.
I need to read through everything again, since I would love to upgrade mine when I get one...but from what i've read, if you change to a tube in a different "family" you have to set jumpers, is this correct for the little dot 1+, or just the higher, all-tube models (little dot II+). I assume the jumpers are for this...though for whatever reason, I kind of expected to see DIP switches:scratch2:.
As much as I would love a all-tube model, something about the layout on this one calls to me, the inside looks much more substantial for instance, plus I probably can't afford more than two tubes
. Would love to try out different op-amps as well, since I haven't delved into those past a 741.
Definitly enjoying reading everything...a excellent write-up:yes:
Edit: Looks like I will wind up with one (looking forward for it). I was looking for the tubes you were mentioning (or equivilent families). A little luck...however, I really can't put down $50 on a couple of tubes. There are some EF91 Mullards on the bay for $13, which is somewhat reasonable, I assume...then there are some 70's VOSKHOD russian military tubes, which are much cheaper, and thusly more suspicious. Any thoughts on these? I read through the topic and the mullards seem like a good set, and really, it's all i'm finding :scratch2:. The op-amp is another matter, I can find TI versions of the 2107, but not burr-brown...I may look for other chips.
I assuming it sounded good stock, but better modified...I may do it over time. I love reading about the tubes though...those valvos look particuarly interesting.
Thanks in advance for any thoughts :yes:
...probably will sound good to me no matter what.
