Speaking of speakers....What's inside??? Can you take a pic of the Front of the speaker itself? I'm curious about something and whether that one has what I think.
Larry
Larry
That console is in amazing shape. I like how good the lettering in the wood looks. Is it sacrilege to update the turntable?
Speaking of speakers . . . I, too, am curious - especially to see the date of manufacture indicated by the production code (6-digits beginning with 220 stamped on the back of the basket rim). I think my 1957 dating may need to be revised based on the GE VRII phono cartridge which doesn't appear to have been offered on the Medalist II series until 1958. If your phono cartridge is original then you've probably got a '58.
ALL JENSEN's. I was actually thinking it might have a variation of a doublehump Co-Ax speaker in it. But the way it's set up is how I originally setup my 51 Coronet when I 1st got it. (courtesy of an old Motorola console). I ended up with a '56 Jensen 15" Co-AX from Batt-Radio. not a Double Hump, but it does sound good.
I got mine for $50 (with no speaker or baffle), and then spent about $100. for the speaker, plywood and cloth, caps, resistors. Luckily all the tubes were good, or I had them in stock. Mine has 4 6V6 in a PPP setup.
Larry
That's odd. Your midrange is the smaller magnet version that was in my '58 C800 when I got it - that model didn't have the adjustable "presence" and "brilliance" controls. The '57 Medalist II that I gutted had a Jensen mid with a cake-pan shaped closed basket and a magnet structure that's about 50-75% larger. I moved the Medalist II parts, including the adjustable crossover bits, to the C800.
So is it a '57 or '58 then?
-D
Well, your speakers were manufactured early enough in 1957 (14th and 16th weeks) for it to bee a '57. It's entirely possible Fisher started installing the "dual-magnet" cartridges before the '58s came out or it was upgraded later. On the other hand, it's got the smaller midrange speaker Sam found in a '58 C800 . . .So is it a '57 or '58 then?
The woofer has 220714 stamped upon it, while the tweeter has 220716 stamped upon it. I couldn't see what was on the midrange (FWIW, the woofer also had LS 547 122 P150 C6147 stamped upon it).
Some photos of the drivers for Larry:
-D
Indeed, beautiful. The Garrard RC 121 Mark II is a good changer for that era. The Stanton 400 or 500 is a good Stereo safe cartridge which could be tracked at 4 grams or the Shure SC 35 cartridge.
