Looking for info/opinion on 1964 Klipschhorns
OEMs just adjusted to penny pinching consumer buying habits. :smoke:
I knew a guy over the commissary for the O'Charleys restaurant chain a while back. He decided to cheapen the ingredients in the food and by doing so HIS bonuses got bigger each year. One day I see my friend who had just talked to the genius manager who was asking people what they thought of his new honey mustard salad dressing after virtually all the honey had been replaced with corn syrup. My friend was silly enough to give an honest opinion which was the new corn syrup stuff stinks. The genius stated that people were stupid and they were going to educate them as to what they were going to like. It took a few years for the damage to become irreversible and the genius to get fired after he ran out of others he could blame the poor end results on.
Sometimes OEM's are idiots who are oblivious to the idea maintaining basic quality standards are how you keep customers.
next steps:
replace the capacitors, they're over 60 years old and are tired. while you're at it, replace the washers between the mid drivers and mid horns. They dry out over time and cause sibilance and distortion.
Swapped out the washers between the squawkers and the horns - the old ones were rock hard.
Having said that - swapping them didn't help with the sibilance and distortion at all.
Any thoughts on what else might be causing that?
I still have the original crossovers...from 1968, and they have a fair amount of corrosion on them.
Understanding that looks don't necessarily translate to operation, could they be the cause?
the crossovers could be leading to distortion. it might also be diaphragms in the mid or tweeter drivers; the tweeters were never great. first replace the caps and see where you get.
I would also loosen and tighten all the screws on each board.
Thanks. After I changed the washers on the squawkers (and it had no impact on the sibilance/distortion), I went through the cabinets and checked/tightened all fasteners; then took out the boards; removed all the screws; wire brushed the leads, the contact points on the board, and the screws, and put everything back together. No change. Seems like the caps by themselves (or the entire crossovers), and diaphragms are all that's left...?
Thanks. After I changed the washers on the squawkers (and it had no impact on the sibilance/distortion), I went through the cabinets and checked/tightened all fasteners; then took out the boards; removed all the screws; wire brushed the leads, the contact points on the board, and the screws, and put everything back together. No change. Seems like the caps by themselves (or the entire crossovers), and diagrams are all that's left...?
I would run the input through the crossover as usual but remove the tweeter connection and see if distortion still there through the mid and bass. If distortion still there re-attach tweeter and remove midrange connection. If needed do the same for bass driver to see if you can isolate the offender.
They are some rough looking XO's! Think they need all new parts, maybe just get new XO's. Adding dampning material to the horns might also help. They can ring, that makes them sound bad. Think in the end, you will replace the Xo's, get new drivers, also dampen the horns.
I started a new thread about chasing down sibilance/distortion in the Klipschorn, and it was suggested I keep this thread going vs starting new ones. So, I will do that, and let the other one die.
I'm troubleshooting the sibilance/distortion on my 1968 Klipschorn.
I've already changed out the washers on the Squawkers, and cleaned up the contact points on the connection bar (I'm sure there is a name for that, but I don't what it is).
Next I...
Disconnected the tweeters, squawkers, and woofers out of the system, and play them one set at a time.
I'm not hearing any problems when the tweeters or woofers re playing by themselves.
I only hear the problem when the K-55V squawkers are playing.
Are there any test I can run on the drivers?
Am I looking at bad diaphragms?
If so - Crites is out of diaphragms - is there another good source for diaphragms for K-55V drivers.
The evolving plan is to change out the caps (should be here by week's end), and the tweeters (should arrive shortly after the caps).
Then see what (if anything) changed.
Next I...
Did you check the DC resistance?
"Did you check DC resistance on the driver with a multi meter? If I recall correctly the meter should show a resistance somewhere around 11 ohms plus or minus. The KV55 is a nominal 16 ohm driver."
One driver (which has some distortion) is 10.8, and the other driver (which sounds far worst) is 8.9...
8.9 ohms sounds too low but someone with a bit more knowledge may be able to comment if that value is within reasonable range.
You might want to disassemble the K55 drivers and visually check. It is not too difficult. After screw removal they may feel stuck, but with gentle persuasion, they will come apart. Just be careful to lift straight up so as not to damage the voice coil. It is possible that there is dried up gunk in there or you might see physical damage to the diaphragm. You can also clean the voice coil gap. YouTube has videos showing cleaning methods to remove garbage from voice coil gaps. I remember when I changed out the washers on my K55’s for the first time, half of the metal screen was packed with dried up old washer material.
De-soldering will be required to remove the diaphragm from the driver assembly.
The Speaker Exchange may have the correct diaphragms in stock, although a bit pricier. As someone mentioned the A55G is also an option but again you would be spending more $$$.
Thank you for your help. I have the tophat apart right now for other maintenance - I'll check this out.
It was a good day! I swapped caps tonight - there is way more overall detail and the mid & bass are richer/fuller. I have to do more serious & lengthy listening to get a better read on the impact.
Distortion is still there, and may even be a bit more pronounced - but it’s only there in certain passages, of certain songs as before. I “may” be on to why - more to follow after I check a few more things.
All-in-all, an easy update/tweak, with immediate impact for the better.
Opened the drivers for the squawkers. Everything looked as it should. Cleaned the voice coil gap since I was already there. Put everything back together.
PROBLEM SOLVED...(cross my fingers).
I'm reasonably certain my sibilance/distortion issue is resolved.
I kept going back to the same recordings I was having issues with, to see if the new rubber washers, new caps, and cleaning the voice coils on the squawker drivers solved the problem I was hearing - but, nothing helped. I started to suspect that the sibilance/distortion on "some" portions of "some" songs, were not speaker-related at all, but potentially something wrong with either my front end, OR, something inherent with the recordings I'm using. To that end, I compiled a playlist of songs that folks on the internet consider above-average recordings/productions. Another words, tracks that should present little-to-no issues on playback.
Well, I've been streaming for two hours now, the songs on that playlist. So far, I've not experienced sibilance/distortion issue I had before. Then, I went back to the recordings that took me down this path in the first place - same problem as before. I went one step further and plugged my in-ear headphones into my MacBook and played the problem songs - yup, it's the songs. Don't know why I didn't do that in the first place, but, oh well....I'm here now!
SO, I've resigned myself to the fact that the recordings I was using were flawed - not the elements of the speakers themselves. The reason I was not hearing these flaws in the recordings before is that the Klipschorn are just that much more resolving than the speakers I was using prior...putting any issues with the recordings (or your upstream equipment) much more in your face/ears.
Got to admit - the sound after putting in the new caps is terrific. Don't know if it's the caps themselves, or the fact that they are no longer 57 years old and exceptionally tired...
SO, next step is to live with things as they are for a while, and listen to LOTS more (and varied) music.
Then, change out the tweeters - from everything I've been told, that's a no-brainer and impacts the mids, and bass as well.
Horns are incredibly revealing. I can hear things like breaths, a spit valve that needs to be emptied and overdriven mics, etc on my horns, that i can’t hear in my car system.
Have been listening non-stop since this morning, and it is incredible the level of detail I’m hearing…like you said, breathing, valves operating…amazing.
I put making false walls in the queue, so I can move them into my 19x29 living room, and experiment a bit with the space……
