First, I let me confess that I've gotten very spoiled working on things like the Sansui AU-555A and the Hitachi SR-1100, which were designed to be worked on at a later date and pretty much go forever with a little love and knowledge.
I loved the 380R at first as it had all the bells and whistles: power meters, triple tone controls, IEC power cord, massive aluminum face.
But...the power switch is a nightmare and goes open. You have to dissect it to clean it, then you've got a few years before it needs it again. The last time I had to do this, I accidentally broke one of the discs (it's an OFF/ON/SPKR A/SPKR B cluster-intercourse that's jammed into a very tight spot) and that was the end of the proprietary switch. Inside, the quality is just not there, with some parts crammed into tight spaces and others dangling in the breeze. The insides show cost-cutting and haste: the 380R was built in an attempt to save Scott's skin during the Spec-Watt Wars. The sound is excellent, however, so I left the dead switch in place and rigged an HK 630 ON/OFF switch into the rear panel--DC offset, if I recall, cannot be adjusted and it's on the high side--so there's that aspect, too. FM started to fail but I was able to coax it back to life by wiggling a few screws on top of the tuning head and cleaning the contacts with D5.
So, a mixed bag. If you can find one for $100 or less, I'd say jump on it. If you fall in love with it's looks and want big, impressive sound (though not necessarily accurate), then the price is up to you. It's got a special look that departs from the blue lights-on-black theme and that appealed to me. Working on that switch got very tiresome, and even leaving it in the ON position and using a power strip didn't alleviate the problem. I was impatient the last time I wrestled with the switch; now that you know about this you won't make the same mistake! It does sound fantastic--as good as it looks--I just wish it was built better. The earlier Scott R74S I also own is much better built, much easier to work on, but not as dramatic or impressive looking.
