Hi all hoping to get some help on my Luxman L-100, it’s started blowing the main fuse and the w04 rectifier keeps shorting on the power supply board d901
outputs all test good as do the drivers, the amp is recapped excluding the main filter caps, confirming able to get ~57.5v +/- when testing the power supply new trimmers installed too I did notice adjustments hardly make a difference.
bias and dc offset are calibrated well with original trimmers and seem to hold steady.
The rectifier and 3.15a fuse blow on power on, any tips where I can look next to hunt this issue down? Thanks
