Did some work with OP via PM.if I disconnect the left hand power amp module the amp works fine
Just to clarify, removed pre-out/main in links then amp powered up/relay engaged normally.
With the link removed I measure 0v on start up and when it clicks out of protection it spikes to between 5v and 15v and after a few seconds clicks back into protection and drops 0vIf you remove the link between the pre and main on the left channel, do you have 5V on the pre out center pin, or the main in center pin?
Cheers Thankyou! I’ll check these and report backI would start on PB639. Check the input and output pins to see if there is DC. Q501,Q504 and D501 are all know offenders.
Tony
Good news! I replaced q504 and q501, q504 had a pretty low hfe about 200 the rest circa 500, I know what you mean about broken wires I had to resolder half of them back to this board, upon power up it’s stayed out protection for 10 minutes and no dc on the links. Dc offset is steady now too. I ran out of time to do anymore testing today and I don’t want to call it a complete success yet, I’m going to do more testing tomorrow and re do the power supply and bias adjustments first and see if it holds up but looking positive!! Will report back tomorrowI would start on PB639. Check the input and output pins to see if there is DC. Q501,Q504 and D501 are all know offenders.
Tony
So my joy was short lived again, after 5 minutes or so the protection kicks again I noticed the voltage on the pre amp links has reduced and spikes about 1.5v now, bias current remains steady and dc offset at the speaker terminal spikes approx 5v…I would start on PB639. Check the input and output pins to see if there is DC. Q501,Q504 and D501 are all know offenders.
Tony
Yes I think so too the only ones left I haven’t changed are on the eq phono board I’ll start there and try not to break any more wires!These are loaded with those 2SC1345s. It is likely one or more of them is the issue.
Tony
