Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Get a very small spring pin (basically a piece of steel rolled into a pin), drill holes in the shaft parts, and press them together. If you size the holes and pin right, it should be good to go. Smallparts.com has spring pins.
