Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I have a broken stop switch on the servo drive unit of a Luxman RX 102. Does anybody have a known source for this part? Is there a substitute available? Thanks.
It really sucks! I was putting the repaired sucking mechanism back into it's bracket when one of the wires broke off the pin on the switch. Discouraged but undaunted, I drilled a tiny hole in the switch near the broken pin and was able to solder a wire to the switch contact inside the switch.
Then ANOTHER wire broke, and this time I couldn't fix it. I'm going to try and substitute another microswitch here, but a lesson was learned: a drop of five minute epoxy securing the three wires to the case of the switch would have prevented this and I'd be NOT WRITING THIS POST.
