C103, C104:
All of the signal passes through these 47uF 16V Rubicon Black Gate F capacitors.
These lil' darlins' are near 40 years old! How they holdin' up?
1: 45.5uF, ESR = 0.31Ohm, Vloss = 0.6%
2: 48.97uF, ESR = 0.29Ohm, Vloss = 0.8%
To be replaced by Elna Silmic II
1: 47.53uF, ESR = 0.52Ohm, Vloss = 0.8%
2: 47.27uF, ESR = 0.56Ohm, Vloss = 0.9%
What, if anything, should a neophyte read from this data?
'Cause, Ain't Broke Don't Fix It is pitchin' a fit!
And Mr. Fixit says you can't argue with physics and these "lil' darlins" should have been put out to pasture a long time ago.
Imho you got lucky with the Black Gates. So far almost every one that I have seen has been moderately to severely degraded.
If you want to get comfortable with what you are doing just decide on your goals, and if you are going to want to learn something, and if you are going to want to do this sort of thing again in the future. And if you want to insure good operation for many years in the future.
There is only one way that I know of to accurately check the condition of a cap, and most other components, and that is to un-solder at least one leg.
Personally, since I have to go that far, and since I will want to re-solder each and every connection in the unit, I just remove the part.
I do test each and every old and new part, and document them. I want to build a picture of the condition of the unit, and I want to sort and match the new parts. I want to make the time spent worthwhile, so I have found that it is best to be methodical and to try to stay with "best practices" as much as possible.
Documenting what you see and are doing gives you something to work with in x number of years when you see another one of these amps and you have forgotten the details, and it gives you something to work with in case something goes wrong with this one.
I am
never, ever, going to re-install a 30+ year elco, except possibly the main PSU filter caps if I can't find a suitable replacement. I do not re-install old carbon film resistors, diodes or zener diodes unless I have no other choice, and if I do I document where they are.
Those parts have been removed, in most cases I have new items on hand, and they are not expensive. I have already subjected the traces to heat while removing the part and only want to heat them once again, so for me, it makes sense to put in new, tested parts.
Re-installing old elcos is just pre-programming the next point of failure in my opinion.
In the end the equipment is your property, to do with as you want. Make your choices and don't let anyone else dictate your choices. But if your goal here is to learn something, then by all means learn the right things.
