MAC 4100
I picked up a MAC 4100, serial number BY2457. I have emailed McIntosh Labs and requested the correct schematic but I'm not sure they are going to reply. The MAC 4100 seems like a nice receiver worthy of restoration. I'd appreciate any comments or assistance identifying the correct schematic and history on serial number BY2457. Thanks.
Sorry, unable to provide a direct link. Must scroll down to MAC4100 then click on Service Manual (upper).
http://www.berners.ch/McIntosh/en/Frame_Matrix.htm
HTH
Thanks for the links. Do you know if there is a way to determine when serial number BY2457 was built? Just curious... Thanks.
I recapped a MAC4100 last year and have a thread here on AK with a full Mouser parts list. Should save you some time if you're thinking of recapping it. It's a great receiver. There were a few variations of this receiver - mine was an early one, but I don't remember the exact details at the moment.
Enjoy!
-Matt
Enjoy!
-Matt
Hi Matt. I just read your interesting post about the speaker protection relay. My 4100 (BY2457) has a 48v coil. It is not a Magnecraft 78RCSX-11. Were you ever able to clarify the issue? Do you have a source for the correct relay? Thanks.
Can someone confirm that MJ15003 and MJ15004 are the recommended replacement output transistors for the 4100, serial number BY2457?
Also, the contacts on the speaker protection relay are badly pitted and I'd like to replace it. My relay also has a 48v coil which seems to be different than the Magnecraft 78RCSX-11 I've seem suggested on other posts. If anyone could share a source for the speaker protection relay it would be greatly appreciated. Thanks.
Hi Scott,
Yes, I believe I resolved the issue by installing a relay with a 48V coil. I'll have to dig up my notes, but that is what I recall right now.
-Matt
I'm trying to resolve some problems with my recently acquired 4100. When I feed the preamp out into another amp, everything works as expected; that's the good news. The bad news is I get nothing out of the power amp output and there is no voltage on the coil on the speaker protection relay. Can someone suggest the next step I should take to begin to isolate the problem?
I am currently feeding the preamp output of the 4100 into the line input of a Onkyo 8220. I've tried all three speaker outputs on the 4100 (and pushed in the speaker selection switch) with no luck. Any additional thoughts on the next step to isolating the problem? Thanks and I appreciate your assistance.
Check the yellow highlights
Not sure why you still want to use the Onkyo.
The MAC4100 is old but if it’s operating per specs then the Onkyo is not needed
Power off, unplugged, work all the switches and knobs full range 20-30 times and try again. I have one of those and there was no output when I first got it. Dirty switches all around. You don't mention the preout main in jumpers so make sure they're clean and connected too.
Keep in mind the MAC4100 uses jumpers to make the connections from the PRE OUT to the MAIN IN jacks. If you're using RCA ICs, are you connecting the cables between these jacks? I realize this is obvious but just wanted to be certain.
I would guess it was built in 1979, may be early 80. Could look in my "tickler" file to see what the serial numbers were for ones I sol in '79 but.......
The MAC4100, I believe was the best receiver ever built and even at $1500 in 1979 was the best value out there.
It deserves a complete and thorough restoration by a restoration tech.
With a complete tuner alighnment expect a labor cost of 7-8 hours.
What are your goals for this unit?
There are many threads out there highlighting the restoration of one of these or it's non tuner sibling the MA6200.
Thanks to everyone who replied to my post. Here's the story on my newly acquired 4100:
I picket up the receiver from a friend who had it sitting in his closet (along with a lot of other super-cool McIntosh equipment). We fired it up and it worked fine for about 2 minutes. After a few minutes of operation, the left channel power indicator pegged into the red and the speaker protection relay contacts started to glow (literally). We quickly turned the receiver off and after a few minutes we tried again with the same results. We took a closer look at the speaker protection relay (Eagle 48v) and the contacts were fried. We cleaned it up as well as we could and tried again with no change (still cut out after a couple minutes). My friend concluded that replacing the output transistors would resolve the problem (I was skeptical). In any event, I replaced the original output transistors (RCA 132188-9) with ON MJ15003-4 and now the speaker protection relay does not operate (no voltage at the coil) and I get no response from any of the 3 speaker outputs on the 4100. The preamp and associated inputs (AM, FM, Phone, etc) work fine when I route the preamp output to an external amp. I'm guessing the problem is either in the channel drivers (045219) or maybe the power supply board (045217). I am hoping someone might be able to help me identify some tests I could perform to isolate the problem. My intention is to eventually restore the 4100 but my first step is to get it working. Any assistance or advice would be greatly appreciated! Thanks.
Build yourself a dim bulb tester if you are going to probe around inside without the proper test gear.
Expect to rebuild the power supply.
Without a variac a dim bulb tester will allow you to compare voltages between good and bad channels even though the voltages will be low because of the limiting.
I would be surprised that none of the resistors on the driver boards did not act as fuses when the outputs shorted.
Sorting through the output failure will take some basic trouble shooting.
You can monitor the input into the relay to observe what you are getting out of the amp sections. Obviously a scope would be best.
Thanks for your reply. I was hoping there was a test I could perform with my volt-ohm meter that would isolate the problem to the power supply board or the driver board(s)? I also noticed there is no information on the schematic about the speaker protection relay (it's not even listed on the parts list). Am I missing something?
