I would first separate the preamp section from the power amp (pull the jumpers) to see if the noise is coming from the power amp section or from the preamp section.
If it still pops therefore from the amp section, you will need to do a stress test.
A few months ago I showed a picture of MA6200 failing a stress test of the main filter caps, while the main filter caps have been surprisingly resilient they are due to start failing at sometime.
If it does not pop with the two sections separated you would have to suspect the preamp section. I just recap all sections now, driver boards, EQ, PS, loudness, etal.......except the tuner unless the tuner needs a alignment......
