Good suggestions as well- just be careful the "goo" will not eat the platic up!!
DC
Use it at work all the time as well as stuck to my Ewave horns.:thmbsp:Did you remove the L-Pad from the cabinet? How could you see what to do if you didn't....?...On the Mach 1's I sprayed sound deadener on the recapped network plastic and on the back of the plastic plate where the tweeter/ tone control are mounted on the Mach 1's. Do no spray into the L-Pads....
... Next I went into the upper horn area of the Mach 1's and wrapped fiberglass around the horn lens and stuffed the remaining area as well...
I wrapped mine w/old, worn out long-handles I had in the bottom of my chest of drawers.![]()
I've thought about the insulation, myself. Removing some or adding some to test the effect on Q factor.
I install dowel rods I had around the house (1 inch boys) for the side-to-side bracing.
I didn't get to fully audition the end result. But for my ear, the improvement was there-
Slight, but there.
I'm not getting the bell ringing from the woofer, however.
I believe I'd have to pump up the volume for that to happen...
By that time, the room would be too full of sound for me to pick it up.
I'm not saying it couldn't hurt. Isolation, is for the most part, a good thing.
I didn't get my head into the cabinet- is the L-Pad/Horn plate screwed to the speaker front or is it glued (Christ's sake) ???
Each time I've worked on bracing, stiffening, padding, damping any of the many and various structures in a loudspeaker driver and/or enclosure, results were immediate and apparent.
That type of mod is usually very cheap, simple enough and not too time consuming. I feel this should be done before worrying about cables or other "last ditch effort at improvement" type of mods.
az
Yeh, it dawned on me that I was changing the color of the lower tones. Then that brought to mind my understanding on speaker building. Hi-Fi builders depend on the over-tone of their cabinet design as part of their final sound output..... A few of the "New England" ("East Coast") speakers seem to rely on cabinet resonance to boost their bass sound a bit; really dampening and bracing ARs changes their sound considerably, and they start to sound a bit "dead" if you overdo things, but up to a point, they'll improve....
