I always throw mine into the big food dehydrator at 100F for overnight so it's not tacky at all- otherwise they can be tacky for days and days.
This is probably putting the cart before the horse, but some notes to think about as you build and approach power-on.
Because we are never 100% sure of the convention used to wind the output transformer, (color codes are not always consistent), I always do a polarity test in open loop with feedback disabled before doing anything with feedback connected. (Or you might get a nasty oscillation). When you first build and power on the amp, have the feedback path disabled as shown in the schematic below. The far end of the TBD feedback resistor (if known) is usually disconnected from the OPT output and grounded- this allows the 6AN8 pentode to see the same DC bias conditions it will later with feedback connected. It's not quite so important in this particular design because the feedback resistor is probably much larger than the 1500+220 ohm cathode resistance, but in some designs the tie to ground is required or the voltage amp won't work properly. Here, you can just leave it and the cap out.
If any of your component values are different than the schematic, let me know, and I will update it to prevent confusion.
First thing, collect all of the voltages in this open loop state so we can evaluate if there are any DC adjustments to be made- I assume the power supply is as indicated in the "Jason's notes" schematic. We will want to see right away the high voltages at the positive terminal of each of the power supply bypass caps. Grab the 6V6 cathodes (pin 8), plates (pin 3) and screens (pin 4). Grab the 6AN8 voltages- pentode plate (pin 6), screen (pin 7) and cathode (pin 9), and triode plate (pin 1) and cathode (pin 3)
To check polarity, I use a ramp waveform like that shown below. Scope this coming right out of the signal generator to see what the input to the amp will look like. When this waveform is right side up, the ramp travels up from lower left to upper right. If you inject this into the input, and the output is the same, it is non-inverted, it's safe to proceed connecting up feedback. If it's inverted (ramping down from upper left to lower right), you can either flip the blue and brown primary leads, or swap the secondary leads, pick one, whichever is easiest.
From there, at a very high level, we will proceed with:
With 1kHz sine, push the output up to squashing, then clipping, to see if it's symmetrical and well behaved.
With 1kHz sine, measuring open loop gain, and deciding what closed loop gain you want.
Use a ~20K pot to dial in the closed loop gain you selected, to determine what the feedback resistor will be.
Look at the 10kHz square wave response, and choose a feedback compensation cap for proper response.
Again look at maximum power at clipping, verify input amplitude to achieve maximum power
Stability testing- into open output (no load) and with small capacitive only load.
Frequency response at 1 watt, Power Bandwidth at max power minus 1 dB.
