Generally to get open loop gain you would use a small output- around 2V works well.
But, using the third picture, Vout = 9.68 and Vin = 7.18mV
AV = 1,348X = 62.6dB, pretty ridiculously high. And this is with 8 ohm output into rated 8 ohm load? Huh.
6an8 pin 1 and 3 have 39k 1 watt. Pin 3 has the 39k then a 5k trimmer then ground. I do have a 10k I could change it to.
Generally the idea is to be able to set upper and lower resistors equal to each other (or slightly above or below). You might throw a 1/4 watt 470K in parallel with the lower fixed resistor to drop it to around 36K.
6V6 plates are lower than the screens, still have 0V dropped through the choke. (shorted maybe?) 6V6 biasing is unchanged, looks great.
6AN8
Pin 1 - 166
Pin 2 - 58 (pentode plate, cathodyne input, looks better than before)
Pin 3 - 64 (cathodyne cathode, 64V looks great.)
Pin 4 - 21 (elevated filament as expected)
Pin 5 - 21 " "
Pin 6 - 58 (pentode plate, cathodyne input.)
Pin 7 - 18
Pin 8 - 0
Pin 9 - 0 (There is our low resolution incorrect voltage reading again. Need to buy you an auto-ranging voltmeter.)
The cathodyne is passing 64V/(39K + 5K?) ~ about 1.5mA. The lower output is DC 64V at idle, the upper output is DC 166V at idle, meaning you are dropping 64V across the bottom resistor, 64V across the top resistor, and 102V across the tube. Looking pretty good there.
10uF - 230 - I dropped this to a 47k and I still get 230vdc after it settles. Guess I need to keep going lower. I'm sure there is some math that gets me the right value.
Well, with (333V-230V)/47K you have about about 2.2mA flowing. It's not a straightforward calculation because as you decrease the resistor the current increases, partially defeating your increase. I would try something in the 15K range and see how that looks.
More questions about this choke. The original 169BB schematic shows the choke and/or a 470/2w resistor. The choke only has a resistance of 56 ohms. I'm thinking there should be more resistance. Should I have both?
I would not. Dropping resistor was used to provide cheap resistive isolation (forming an RC filter stage) to decrease ripple. Chokes are more expensive, and the inductance provides much better filtering. You have on the order of 78mA + 3mA = 81mA at least flowing through that choke, and with a 56 ohm DC resistance you should be seeing on the order of 4-5V drop across the choke. If you don't, it's either mis-wired, or shorted.
(continued below the pictures)
I'll be honest, I don't really like how this power supply is designed. In this factory design (modified by Jason?) the choke is the only drop between B+ and the screen supply. The choke likely has a lower DCR than the CT to plate half primary winding of the output transformer. This means that the screens will track higher than the plate voltage, especially at high power levels which is generally a bad thing. This could be fixed with a dropping resistor, but I still think this supply can be a bit better.
Generally, a push-pull amp will have the filtering scheme shown on the right. B+ (OPT supply) is usually taken from the second cap, which minimizes ripple yet still provides good stiff regulation because of the low DCR of the choke. The dropping resistor between the 2nd and 3rd cap for the screen supply is usually sized so that the screen supply tracks pretty well (or just below) the output tube plate voltage when under load at near maximum output power. Usually this is less than 1K. The second dropping resistor for the Vpre supply would then be larger, and fairly arbitrary to achieve whatever preamp supply voltage you like. It's not a really bad thing to take B+ from the first cap, but from the second is so much cleaner.
