huh . . that sounds funny
I have a 185 amp that I need to bypass that first phono-gain tube on. . . how hard is it do do ?
just run the inputs to the grids of the 12ax7 ?? :scratch2:
Use the AMP175 input config- from the center pin of the input RCA jack, through a .01uf cap in series, then a 470K resistor to ground, then a 47K resistor in series, to the first-stage grid of the 12AX7.
That'll definitely work... by doing this, you will have converted the amp to an AMP175, for all intents and purposes.
You can "upgrade" to an .022uf cap, if desired... IME, it works fine, and seems to help make the bass more "linear" (ie "smoother"), to a lower cutoff bottom-end frequency. Especially if you upgrade the other coupling caps proportionally (if it's .047uf, use a .068 or .1, for example) in the circuit. The exceptions are the compensation caps (the tiny ceramic caps to ground)... definitely LEAVE them the SAME VALUE, in order to preserve stability in the amp...
Regards,
Gordon.
Regards,
Gordon.
WRT the .0033 and .047 uf caps... those are different stages!
Markus,
Just wondering how far you've gotten, I just finished cleaning up the input circuit as per Gordon and the 175 schematic, huge improvement.
Markus,
Just wondering how far you've gotten, I just finished cleaning up the input circuit as per Gordon and the 175 schematic, huge improvement. When I first got it I did a quick bypass, but there was still some of the phono "stuff" in the way. I basically gutted and rewired everything from the input jacks to the 12ax7's.
Gordon, I used .02uf ceramic disc caps at the inputs, would a different type make an improvement, AND if I used a polarized cap, where does the + go!
Thanks Again
What ? NO ? Your not going to get off your Butt and finish the Base ? LOL!
Glad to hear your making progress with the Magnavox 185 Mark. I look forward to hearing it when finished.
Regards,
SixCats!
