Sorry Tom, I'm not sure why I didn't get a notification of your post. I appreciate the offer. I ended up finding the tuner section, and have been getting by with the AMP142AB schematic even though I have AMP142CC.
I replaced most all of the filer caps with the exception of 1 half of the 30/30uF@475VDC in the tuner. I screwed up my shopping list and shorted myself (1) 30uF@500vDC cap. I also replaced the (2) .1uF and a .022uF poly caps and (2) 470K resistors that tested strange. I serviced the turntable and my dad gave me this awesome rubber renewer that took all of the wobble out of the drive idler. The turntable runs about as well as I can expect it to for 62-63 years old. The power amp is working the best, and the tuner the worst. FM and AM reception is spotty and somewhat weak for the most part. About 75% of the tubes were bad. Without really looking at it I found that the one 5Y3 that was in the socket was actually a 5U4. I need to replace 6U8A, 6BZ6, and 6CY5. They tested really weak on a Triplett 3444 tester. 3 out of 4 6V6's were weak, the tuner had a 12AT7 instead of a 12AX7 (what is that a gain factor of 40 vs. 100???) and needed both 5Y3's. My dad had all of them and they are on loan. Having said that everything DOES work. I just need to get those tubes, do more cleaning, and if my 2 prong isn't causing it or the one remaining 30uF, figure out the ground loop issue I have. It is coming from the tuner because if I remove the single RCA input cable from the amp the hum is gone. That is it for now. Thank you everyone.
