Kegger
R.I.P. 1/12/1966 - 6/1/2017
On mine/Andy's because there was only a pot and it was originally wired this way
all heaters are from 1 set of heater windings, so each side of that heater winding
goes to the outer taps of the humm pot, then the junction of the 10ohm resistors
and the 330ohm resistor from just 1 pair(either pair) of outputs goes to the center
tap of the humm pot. (so it goes between the 10ohm resistors an 330ohm resistor).
And yes the 10ohm resistors on each cathode are for measuring the output current.
If you were to use 2 6.3v windings, say half of the amp on each winding then you'd
want a second humm pot and connect just like above using one output pair per pot.
To form a "virtual center tap" (if not having a pot or removing it)
You can also do away with those pots using 100ohm resistors from each side of the
heater windings an connect the output cathode to the center point of the resistors.
Just in case you or anyone else wanted to know, the reason for doing this is to float
the heaters on a small amount of DC voltage, to both help in humm, and because we
are direct coupling the input tube to the phase splitter we are raising the heater with
respect to cathode as to not violate the maximum spec allowed on the tube.
