RUmad
Apparently I messed up my Maggie today. It’s a 9304-00 that I modified to the DCG circuit, but with original OPT’s and no buffer. I don’t use it VERY often, but when I do it’s been perfect. Always reliable, sounds great, runs nice and cool. I finished building a prototype preamp a couple weeks ago and for testing/debugging I switched between this Maggie and my 8802 (also modified in DCG/thorpeJ fashion). Figured they could use the play time.
So anyway. Today I decided to remove the 100k pot and just retain the 470k resistors. After that, while still on the bench, the left 6EU7 must have been crooked so I pushed it straight, heard some crackling and saw a small arc in the tube. Long story short, after thinking the socket was faulty, I found that the power supply wire (pin 7) was a cold joint. Soldered it proper and figured I was good to go. The cackling and arcing is fixed. Here’s my current trouble, that I can’t figure out and frankly don’t know how to test/troubleshoot.
I left it on the bench to warm up and make sure nothing else going on, and after a short while I noticed the transformers were all very hot. Like I said this runs very cool normally. I decided to check the bias, mostly because I mounted the EFB pot in a stupid spot and I easily could’ve bumped it. Turning the potentiometer that controls the EFB does absolutely nothing. No voltage change whatsoever. I shut it down immediately. No red plating, I just didn’t want to chance burning up my tubes or trannies. I’m totally baffled. I wasn’t working anywhere near the EFB regulator, but I assume I did something. I would really appreciate some input here. I don’t see anything out of place. Nothing looks or smells smoked. I don’t know how to test these things. I can get some voltages if anyone needs them tomorrow, probably get pics if necessary tonight. I’m having an ‘all thumbs’ day today and I’ve packed it in.
