No, that resistor being off that much will not kill the channel. Could possibly make it distort but no way it could kill the channel.
I have to so some thinking now. I am pretty sure the culprit is PC5. You can't just get one. Mainly, PC5 provides for the biasing of those two transistors and their own idea of negative feedback. It is just a bunch of resistors. One of them is open.
As you now see, troubleshooting isn't really about finding out what the problem is, it is as much about finding out what it is not. What I am having trouble with now is that it is not making sound at all. Most failures I think, resulting in those DC voltages should make some sound, but probably distorted.
With it off, measure the resistance from the emitter of Q11 to ground. It should read like 11K. Also, it should read 1K to the negative side of C13.
If all else fails, we just eliminate all this **** and find a spider board and an OP AMP. Half of the tone circuit in these things needs to be scrapped anyway for good sound. If we go that route, it is not that expensive, but can be a bit tricky, and in no way can be considered a restore, nor will it be restoreable. It will sound better than new, but it will not sound like new.
Actually it could be done, but really if you get it fixed "right", which means tacking on resistors to the PC5, I had such a list of modifications anyway that the end result would be the same. I just like to avoid modifying if possible.
They had no reason to use that PC5 dohickey. What, to keep their design secret ? All it is is a low impedance preamp. And right there is their circuit right in front of your eyes. Just a bunch of resistors, and Howard W. Sams company reverse engineered it quite handily. Or did they ? That is another thing, they could be wrong. Wouldn't be the first time.
Anyway, too much more of this and we throw up our hands and say "ENOUGH" and find, literally, a 4558 generic IC and be done with that ridiculous circuit. They sell a little board you can mount the IC to, even a surface mount, and hook up wires. Problem is most OP AMPs are split supply but are adaptable to single supply. Now the ones that are intended for single supply are intended for a positive source and this thing has negative sources. So we have to adapt a split supply unit for this, It's just a matter of a few resistors.
So, I hope you find too high resistance from Q11 emitter to ground. If so, the fix will entail one resistor. If not, well you know...
