not sure that the bass control really can work outside of ceramic phono cartridge duty.
Maybe it can, if the proper resistance is added, to take the place of the cartridge ??
Regards,
John
Unless you've got a source with an output impedance of a few meg, I don't expect that will do it. Most ceramics work into a few megohm impedance. A typical CD player or whatever is probably well under 100k. Maybe lots of series resistance would get it back, but its probably not going to sound amazing. This is probably a tone control circuit I'd just ditch or replace with a circuit out of the RCA manual or similar.
just make sure you get the right two, otherwise it will either do nothing, or be a dead short across the power lineIf you can follow the wiring on the turntable, the two that go to the switch are the ones you need.
Of the various changers used in consoles over the years, this is by far not the worst. Mod it for a magnetic cartridge and you might be surprised at it. The Collaro changers were right decent pieces, and they have this really cool record sizing process that uses the tonearm.
[/B]
That"s the best idea,the tone controls are already out of his chassis...
I left the tone stack in my RCA,,, There is 3.3M at the input end of teh 2M bass pot on the RCA, it works well with a CDP, and tape deck, so far... I actually have to turn the bass down...
Regards,
John
