cubdog
banging through drywall
Cub,
I think he posted the stuff he used earlier,,, I just did the same thing on a little RCA amp I'm working on and just used silver polish,,, It came out like his...
Regards,
John
Great, thanks a lot!
cubdog
Cub,
Regards,
John
If your audio source is low impedance, it won't. What was the impedance of a ceramic pickup anyway? One could insert a pair of resistors of the equivalent resistance to simulate that impedance, and then the bass control should have an audible effect.
Depends on if I think I want to do this just for doing it.
Someone in this forum will take it off your hands if you do decide to not proceed.
This is the socket for the 6EU7. When I was replacing one of the .1uf caps and dealing with the glob of solder they used to connect 400 things to the one connector it pulled up. Center of picture next to cap. Can I set it back down and put epoxy across where it broke ?
