Magnovox Phono Console
Both of those schematics are about the same. Neither has tone controls though, so its possible neither are correct. Thats what I was looking at without thinking about those tone controls.
Are those caps from the schematic, or verified in the unit?
33uf 35v should be fine for a 30uf 25v. The values on these things aren't super critical. The original tolerances were pretty wide.
All the caps I ordered are from the unit, not the diagram. Hopefully my eyes saw everything correct now, didn't see that . in front of the 1. For some reason I was thinking 10000mmf was .01uf
thaxman, the cabinet is sitting in the garage. You want it ? I'm thinking if the amp turns out well I might pull the table.
I have a SS Maggie amp & table. I have no use for them b/c the AUX are mono. But the cab they came out of is being transformed into a mid-level stereo/5.1/htpc all-in-one. If I like how it turns out, I plan to transform other unloved cabs here and there & see if I can make a buck.
I like the Maggies b/c the side-firing woofers free up room inside the cab. I have a friend who brings cars back from East Coast auctions. I'll have to ask if he likes to make detours.
I'll get it loaded this way.
attachment.php
This is how I'd modify it, changes marked in green. I'd put a coupling cap between the input and the triode, and a 1 meg resistor to ground to bias the triode. If I recall correctly, you plan on using a set of volume and tone controls you already have anyway. So you can remove the ones in the amp. The balance pot is replaced by 22K resistors to ground.
Looks like you're in good hands regarding the amp, so I'm just going to swoop in out of left-field blue skies to suggest...
Please don't just trash that Micromatic record player. I know it is hardly world-renowned hi-fi quality, but it's a good example of an era in audio history, and with a little TLC not the complete record-destroying hideous monster some might have you believe. Cleaned up and nicely mounted, even if it ends up more a vintage decoration than a piece of hi-fi, it should have a chance to live on.
Just a thought.
I'm keeping the tone controls right now.
As for the Micromatic, it has not been discarded and won't be. I haven't even drilled holes in the amp chassis or chopped wires, trying not to. Attempting to add pilot light and switch now without enlarging or adding holes.
Its like spaghetti.
It's also very low volume unless I have balance completely to left or right ? How do you clean the tube sockets ? I think I blew a tube jiggling it in the socket trying to get the one spot it sounded okay.
If I turn it off, swap out tubes turn it back on, sound follows the good tube. I don't understand the low volume unless balance pot is pegged to either side thing.
Also, the bass control does nothing audible to me ?
If your audio source is low impedance, it won't. What was the impedance of a ceramic pickup anyway? One could insert a pair of resistors of the equivalent resistance to simulate that impedance, and then the bass control should have an audible effect.
Beat, can you tell me what you used to polish the chassis? Did you leave it mostly intact just covering the sockets or do something else? I need to clean my Maggie but I don't want to completely disassemble it.
cubdog
Cub,
I think he posted the stuff he used earlier,,, I just did the same thing on a little RCA amp I'm working on and just used silver polish,,, It came out like his...
Regards,
John
