Maranrtz 2325 Speaker Relay Tripping
Does anyone happen to have the part number or cross reference number that I could use to order a Speaker Replay from Mouser? Mine tripped twice in a week and think it needs to be replaced. Thank you.
It could be the protection circuit working as it should. You should at least check for DC at the speaker terminals. Replacing the relay won’t fix anything if there is an underlying problem causing it to go into protection. Also, I think two different relays were used during the 2325 production run. A photo of top and bottom of the power supply board would help.
