Pretty big leap in capacitance. Did you get the polarity correct . If one got put in ass backwards - that would do a number to the bridged rectifiers.Further advice led to replacing caps with 10000ufd 63v caps and was told it will work better as long as I don't go lower than the original capacitor values.
Wrong answer.. You got one in ass backwards.Both caps negatives go down to a common plate base.
positive wires for the positive rail -- negative wires for the negative rail.You can't connect the negative wires to a positive capacitor lead. That puts a dead short to the bridged rectifiers.3 white wire on positive of one cap and 2 red wires on positive of the other.
The local guy I normally use suggested everything I did so far. I'm sure you can understand why I'm here instead of at his door. I'm in South Africa so?Wow...
Simply replacing the bulb NEVER should have caused what your describing.
And it sounds like things went from bad to worse the more you tried repairing it.
I dont intend for this to be mean or anything. But I really think you should take it to someone who
really does know how to diagnose and properly repair vintage amps.
The idea this much power supply damage has already occurred I can only guess what else may have
been damaged that your not even aware of.... possibly.
Do you have any local or somewhat near by competent techs that your aware of?
Also if you wish to give your general location someone here might be able to recommend someone.
