If your protect relay " clicks" then you can check DC offset at the speaker terminals. Bias or idle current checking and adjusting -- there is usually a test procedure in the service manual that indicates these test points.My read up taught to test for DC voltage on speaker terminals.
The DC offset is low enough for the amplifier to operate.If your protect relay " clicks"
Connect your DMM between J709+ and J711- and adjust trimming resistor R763 for 20mv DC repeat at J720+ and J721- and adjust R764 for 20mv DC. Connect your DMM to J707+ and the chassis and adjust R761 for 0mv DC, repeat at J718+ and chassis - and adjust R762 for 0mv DC. You can find the manual for free on HiFiengine, just sign up and the manuals are free.
As long as you are on the DBT you should be safe, if any readings are way off, don't connect your speakers till you get it adjusted. Adjustments should be made with the volume all the way down using the aux input, no speakers connected, and without a music source. If you get it in spec on both channels, you should be safe to remove the DBT and connect to the main power. Once on the main power, you should re-check and adjust as needed. Once it is in spec you should be able to apply a music source and connect speakers.Is there any specific caution I should take?
Thanks Steven. Purchased mini grabbers today for exactly that reason. Will keep you posted. Thank you for the supportExactly. After everything is set, and you remove DBT, I would recheck/reset offset and bias, assuming you have minnigrabber leads for your DMM where you won’t short anything out. Unit off - attach leads, turn on, do setting, turn off, remove leads. Repeat for the other setting.
Yup. I was worried bout that but luckily the kind guys on this forum guided me all the way even with replacement parts and they know their stuff so hopefully all will be well.the 1060 is a nice little amp. Just be careful of the replacement parts you use. If you change the wrong parts, you will wreck that classic Marantz sound.
So I guess I won't hear a click. Will just check and adjust as per above procedure?Sorry, but 1040 doesn't have relay inside.
