In the U.S., all of the stereo equipment of that era (1970's) only used a 2-prong AC plug... no ground pin. In fact, the plug was not keyed so you could even reverse the hot and neutral wire connection into the AC socket. That changed in the U.S., some time ago where now a 2-pin plug is polarized with one plug spade wider than the other. Having said this, I would think that it would be OK to run it that way. But then again, I am not familiar with your local electrical codes. In the hardware stores here, you can buy a "cheater" AC plug adapter that effectively adapt a 3-prong plug to a 2-prong plug socket. So, it sounds like the issue is the grounding of the PC and the 1060.
