Richs_Trains
Well-Known Member
I have a Marantz 1060 that I bought not working and tried to rebuild about a year ago. I recapped everything except P-400 and replaced the fried outputs and the filter caps. When I got it, it was a dead short on the dbt and after replacing everything and adjusting the amps using the recommended way when you don't have a scope, everything works, it is the right channel is noticeably lower in volume than the left. I know it is recommended to change the small transistors on the power amp boards, but I don't really know how to match these up, could this be my problem on this one? Any help, advice, or part numbers would be greatly appreciated. Also still trying to figure out the 1150 from a previous thread, once I get the 1060 right, I hope to get back to it. Thanks as always Rich
