Marantz 1250 Cabinet Model # ??
Ok I did the research usig search here, there everywhere! Penninw on Ebay is a memeber here and makes cabinets for the Marantz models. I shipped mine off to Terry Dewick to go through. It's on route to him as I write this. Here's the specs penninw needs to build the cabinet for the Marantz 1250.
Heres his query
Mark,
I will drill the cabinet for you if you wish. I will need to know the measurement from the rear of the face plate to the center of the front feet and rear of the face plate to the rear center of the feet. I will also need to know the measurement between the center of the feet parallel to the face plate. Since the WC-1 was made for the 10B which has a more narrow chassis than your integrated amp I need to know how wide the chassis is directly behind the face plate at the widest point which would include any screw heads that might protrude. I will open up the front of the cabinet so the unit will slip in. Thanks,
Bill
If anybody could help me with this I will return the favor some how!!!!
