My heritage is 3rd generation Japanese so I am aware of Sensei.
This may be getting more technical than you want, but I looked up the part for Q701/Q702.
FYI, this is the amp that is used in your Main Amplifier, LM381. If you compare the typical application on Page 2, it looks very similar to your amplifier.
The LM391 drives the pair of transistors for the output.
Note that there are two resistors RE and RE' which corresponds to your R741/R743 on your board.
On page 7, the paragraph describes how to adjust "bias current" by measuring the voltage across resistor RE. It says to adjust "RB" on Figure 1 to provide
about 25mA of current. We calculated 10mA = 4.7mV, so we can actually go a little higher (according to the datasheet).
Recommendation: I would go back to your original adjustment of 10mV across the resistor R741 and R742 and leave it at that.
