So, the resistors RE39 and RE40 tested correctly: 10
I guess next step is to test the transistors?
ok so one side of RE39 and RE40 is 36V, and according to the HIFI eng. schematic the other side should be 16V or 18V I can not make out the printing.
Going back to your first post, did this work before you recapped the power supply board (first board you recapped with bad sound after)
Replied to the PM you sent.I'm trying to set the 4.5mV voltages via R735 and R727, and R736 and R728. How long is the recommended waiting time till the reciever warms up? After startup the voltages fluctuating.
Neither, low impedance ones are best in the power supply like Nichicon PM, PW, HE and the like. The ones you mention are audio grade.
If they ran out of a part, but had a higher voltage one in stock, I doubt that they would stop the production line.
The parts you ordered should be fine.
Tom
Tom
