hey, I totally understand you're trying to help and it's much appreciated!
I'm just asking and probing as much as I can, BEFORE making any physical changes (and having to open her all up again)... as much as this is a hobby for me, I have very limited space & time for any work in my tiny apartment, so I avoid all the work I can... it's somewhat depressing to have fixed her all up, only to discover it's not the holy grail of receivers, at least for my ears and my speakers... to make things worse, I never even listened to it before the rebuild, since I just bought it and there was a weird electrical problem I didn't want to risk running it too long
my recap/rebuild was pretty carefully done, and I don't think anything too crazy was done, either in the slight mods I made, and all the parts were of decent quality and those used commonly by AKers in their rebuilds
in fact, in my 2275 rebuild, I used even "lesser" caps (mostly Panasonic FCs and orange films), and that turned out sounding very well... I also used bypass caps on the 2 filter caps... FCs on the power supply board
of course for the 2230, I also cleaned all the controls and switches with Dexoit, and even opened up all the pushbutton switches and added Deoxit Gold (the switch contact surfaces were dry but very clean and silver colored)... applied Faderlube to the pots (ASIDE: ...and "ruined" another Marantz volume control by spraying Deoxit inside, thus inadvertently flushing out that precious grease around the shaft and losing the smooth, tight rotary feel!!!)
stupid question 1:
how is it possible that the caps used on the power supply board affect the sound so much?... I thought this board simply provided electrical power (to be used by other parts of the circuit), and it wasn't in the audio path
stupid question 2:
I seem to have mediocre sound, whether my 2230 is used as preamp only, as an amp only, or combined as an integrated amp (normal)... is the power supply board involved in all 3 cases?... if so, could it (and the caps used here) be the main culprit?
thx
Maybe Pat will apply his particular brand of VooDoo to a Model 2275 next, and really make your day.
With the selective use of additional high quality films in critical locations, maybe Pat will even appreciate a more powerful receiver versus the lower powered 2220B, 2230 or 2215B he seems to prefer. Maybe...
I'm guessing that the requirement of numerous higher value electrolytic caps in the more powerful recever designs may be the reason some, particularly Pat, may prefer the lower powered receivers.
Might the selective substitution of film caps come to the rescue?
Or at least be part of the answer...
Jk has previously posted this excellent article about capacitors and their effect on the sonic characteristics of audio gear.
http://waltjung.org/PDFs/Picking_Capacitors_2.pdf
Worth a careful read if you're serious about your receiver's 'Sound'.:thmbsp:
