Marantz Model 140 power amplifier
arien
Hi,
Anyone have owned or currently own this marantz model 140? Is this a good amp worth acquiring? What is the sound characteristic of this?
many thanks in advance.
This is a good amp... if you don't have to pay too much I would grab it. It is 70wpc which is not a real power house, but as long as you don't plan on throwing big ruckus parties, is plenty of horse power to drive most speaker to a respectable listing level. You can't go too wrong with Marantz in my opinion.
I guess you need to weigh it against cost and what you already have. I know the 140 will give you good service and you could do a lot worse for sound quality.
Just my 2c
140
Nice amp and the blue meters are beautiful. I use it with Klipsch Forte's and it sounds great.
Crite’s modified Forte Is, Crites modified Cornwall IIs (2 pair), Pair Cornwall I’s, Ohm 2's, Dahlquist 9's, Dahlquist DQ-10s, Pair Ar3a’s, Marantz 140 amp, Marantz 170DC amp, Marantz 240 amp, Marantz 250 amp, JWN Tube Amp, MC 30’s Marantz 1060, Marantz 3200, Marantz 3250, Marantz 3300, Marantz 3600, Ampex 550 tube pre-amp/tuner, Mcintosh MX110, Marantz 115B Tuner, Marantz 105 Tuner. A Gaggle of Carver Receivers, Denon Cd, Marantz SA14 V2, Technics SL-Q2, Technics SL7 and an AR-XA. A Grant Fidelity Tube processor.
"Good Music, Single Malt and Old Motorcycles"
Own two of them. Great amps. Might need refurbishment due to age though. Be sure to ask if it has been serviced and if yes, what work was done.
Great amp: I've run mine through JBL50's, Dyanco A-25s, Polk Monitor 7's among others and it sounds terrific through all of them. I've found mine to be really dependable and it sees action daily in my main rig.
Thanks everyone for your responses, appreciate it...
I will check about the service...
cheers,
