I bought a Marantz Model 25 last month and it actually sounds and looks great, so I've been using it as my main system while I finish work on a couple other receivers. But this thing is supposedly from around 1969-1971, so it surely needs to be re-capped at minimum. I'll document the process here in case it's of any use to someone in the future, and for when I inevitably need help troubleshooting.
My parts list, which might not have ideal choices in part due to already having some capacitors on hand. I.e., I didn't try to figure out if certain caps should be "audio grade" vs "low ESR". https://docs.google.com/spreadsheets/d/1E6sDrUQtPXEu3vryZJbCwK78BvqNSiAIxJc6FD-hLWw/edit?usp=sharing
A couple photos of the unit as it was received:
