Marantz Push Button & Knob Removal?????
buffalo
Member
Can someone tell me how you remove the silver push buttons and the knobs on a Marantz 2275. Also are they standard sizes on all the models that are interchangeable?
Don't ever remove the push button covers, you'll crack the switch shafts and you'll have a nightmare on your hands, they seldom require removal for faceplate removal. The knobs should just pull off, sometimes a spoon will help pry them loose with cardboard to protect the faceplate from marring, BTW, welcome to AK, Dave. :yes:
Yup...don't pull on the push buttons. They will break. Knobs pull straight off, but sometimes need a little leverage. There will be a brass ring underneath one of the center knobs that will have to be removed to get the faceplate off.
Have fun and welcome to AK.
Cheers,
Carl
On my 2275(with 2 broken push buttons,) the button is slightly smaller in diameter than the rest of the Marantz's I have. One from a 2270 or 2245 will not fit into the hole in the face plate. Just so's you know......Tim
I have removed Marantz (& other identical ones) push buttons and have not had a problem. I agree that under normal cleaning & manitennance, you should not need to. If you do, make sure the button is in the "OUT" position, grasp firmly w/ thumb & forefinger, and pull it straight out. DO NOT JERK IT AND DO NOT ROCK IT FROM SIDE TO SIDE. You'll likely break the switch shaft as mentioned.
