malotru007
Hope I can benefit from the knowledge in this thread. My Marantz TT15S1 was bought in the US so it runs on 120V 60hz. It was in storage for 5 years. I moved to Italy permanently and brought it along. I read that I needed a step-down transformer and a different pulley size (a 50hz) and I would be good to go. However After buying the 50hz pulley, I noticed that it has the same exact diameter (44mm) than the one that came with my table (the 60Hz pulley)!!!??? (see attached image)
Of course when I play a vinyl, it spins too fast (chipmunk effect). Based on the hap +14%. I know that Marantz makes 2 pulleys:
50Hz pulley (90M31BW262010, or SS-T15/032 from Jap s/m) and SS-T15/031 from Int. s/m 44mm
60Hz pulley 37mm
So my questions are:
pulley picture
TT speed
60Hz pulley 37mm
- Why did I got a 50Hz pulley from my table bought at MusicDirect in the US?
- The pulley size is the correct one for EU, why is it still off-speed?
- What do you suggest? would trying to add some tape, size to the existing pully to mak it bigger solve the issue? Thanks!!!!
pulley picture
TT speed
