I broke something in the left rear channel. Troubleshooting now...
I hate it when that happens :saywhat:
I have the utmost confidence that Kyle will get things sorted out and be back with more news soon. :yes:
Nose back to the grindstone.With the help of catrafter, looks like the root of the amp board problem was found. H735 diode had a bad joint. Testing results coming soon.
I rebuilt the phono board today. Finally an easy task in the 4400. Just 3 'lytic caps and two tantalums. Elna Silmic II for the 'lytics, Panasonic ECQ-V films for the tants. A nice Sprague axial was also installed. The board just folds right out when you remove its mounting screws, just be careful with the insulating paper under there.
The phone board looks simple, what looks scary is the tangle of wires next to the board.![]()
I have found some CDE brand ones (338-3338-ND for the .47UF and 338-3331-ND for the 1.0Uf one but they are rated up to 85C) but I am still trying to find the poly stacked caps.
4400 update - Amp sections installed, bias and offset adjusted. All channels sound great using my DAC direct to main in jacks.
Tone control board is in work now, being a bit of a PITA with low volume on two of the channels. Gonna break out the scope tomorrow for some signal tracing fun.![]()
Good God Kyle, will anything with this receiver be easy?![]()
Fets show up?
On the tone board, where the pots are, I've had issues with the transistors on that board...
