Jailtime
Standin' on a corner
A picture might be worth a thousand words here. In the first picture, you can see the test points for where signal leaves the PF01 tone control. The blue ones are high (correct signal), yellow ones low. The red wires tie to the 1uF caps on PD01, the white wires to the 3.3uF caps.
The next picture shows the 1KHz signal as low. Other picture is 1KHz high, ignore the messed up trace, shaky hand with the camera. Quite a difference there.
I wish that PD01 wasn't such a bitch to separate from PF01, those solder pads look like hell. :sigh:
