If dealing with only DC then no worries with RMS meters. Putting it simply, the true RMS instruments are more accurate than RMS when measuring AC current. The accuracy of true RMS measurements is usually not nearly as good at averaging DC measurements as RMS meters are.While looking at different dmms I found that the one I have doesn't have true rms. I have read several explanations about the difference between true rms and rms. But what I'm not clear about is whether that function would get used working on stereos since we're mostly dealing with dc?
That's good to know!If dealing with only DC then no worries with RMS meters. Putting it simply, the true RMS instruments are more accurate than RMS when measuring AC current. The accuracy of true RMS measurements is usually not nearly as good at averaging DC measurements as RMS meters are.
Thanks! There is not much left to do really. My plan was to let it play for a while and then recheck everything. I also need to hook up my record player to make sure everything is sounding good.Sounds like you are making great progress. Well done!![]()
I also received the tuner alignment set I bought. Centering the tuning meter was quick and easy when following the instructions in the link I posted. I also ended up moving the dial pointer so it's on the correct station and changed the dial pointer light since I had not done that yet. I also adjusted the regulator voltage, dc offset, and bias. I am planning on posting instructions how to adjust everything in case it will help someone else.
That's great! I'm glad it helped.Thank you for your post. I have the same problem with my tuning meter. I read the link you posted and adjusted my tuning meter, use a wood stick and it works great. Otherwise, I might just use a metal tool and cause problem.
https://audiokarma.org/forums/index.php?threads/marantz-2275-fix-and-rebuild.921136/page-2
I'll watch that video. Thank you for sending the link. I definitely want a good desoldering gun. I'll admit that it takes much longer without one. The desoldering tool I have seems to work but it leaves solder on the circuit board. So then I have to follow up with wick. The extra step makes it take even longer.A good desoldering gun makes this work so much easier. I did a short video in the Hakko FR300 a couple of years ago. There is now an FR301, and I think a second generation of that. I wouldn’t work without one.
https://audiokarma.org/forums/index.php?threads/use-of-hakko-fr300-desoldering-gun-video.741463/
She went home today. The owner was very happy with how it turned out. That was nice. One last pic before it left my bench.
After watching @Steven Tate's video I am a believer. Just pulled the trigger on a Hakko FR-301. I had been on the fence for a while. Now is a good time because I've got more stereos to recap.
