I have built two pairs of mass loaded transmission line speakers; both using 8" woofers. The bass and midrange clarity, and the bass extension are simply the best I have ever heard. I have been listening to hifi audio for over 32 years, and these speakers are as good as I could ever imagine.
I used an acoustic modeling program called Hornresp (
http://www.hornresp.net/ ) along with DataCAD, which I use in my day job, to settle on the designs, for the two woofers. The first used the Dayton Audio RS225P-4A, and the second has the SB Acoustics SB23RNXS45-4 - both are 92dB sensitivity, 4 ohm nominal, paper coned 8" woofers.
I have been using a miniDSP 2x4 HD active crossover initially. This is easy enough for me to refine the crossover to a fine level, and on the first speakers, I used the PEQ with a UMIK-1 calibrated mic and REW, to make custom filters to get very flat response.
On the second design, which I am calling MLTL-10 (after the Linaeum Model 10) I was able to use just the crossover and adjust the volume on the tweeters; as a model for an analog crossover. I have now done this, as well, and the parts are ordered. I used XSim to match the measured response of the speaker, using the individual driver response measurements. The crossover is 1st order on the tweeter, plus an L-pad to lower the level and balance the impedance - and 2nd order on the woofer.
View attachment 2331901 View attachment 2331902 View attachment 2331903 View attachment 2331904 View attachment 2331905 View attachment 2331906 View attachment 2331907 View attachment 2331908 View attachment 2331909
