You won't hurt anything so try all 3 and go with what sounds best. As far as lose/gain, you would lose maximum volume off the 2 tap, maybe gain some dynamics off the 8.
Older Mac amps, maybe 7270 and before, seem to like the "minimum, not nominal" impedance of the speaker to not be below 20% of the tap so 6.4 off the 8, 3.2 off the 4 etc. The newer amps can better deal with the current the lower impedance needs if it drops below the 20% mark.
Expert extraordinaire Ron-C has mentioned that some B&W speakers are rated at 8 ohms but drop to 3 and can have a tough phase angle and will usually sound better off the 4 tap even on the newer amps. So try different ones and "listen".
BTW, my "guess" would be you will like the 8.
