The MC250 sounds great when connected to my C27 preamp. And the 2230 sounds great on its own. It's just when I connect them both the resulting sound is not very good. Was wondering if the preamp out levels of the 2230 are much different than those of the C27.
I assume you're using the same speakers for all these comparisons.
What's wrong with the sound?
If it is distorted, the preamp could be over driving the first stage of the amp into clipping. But that would clear up by turning the volume down. Also, my guess is that the MC250 can handle a pretty high input without clipping the input stages.
Maybe the preamp output is too low. Now that I think about it, I once had a Kenwood KA-6000 integrated amp. It had preamp-out / main-amp-in jumpers, but the voltage levels at the jumpers were much lower than most normal preamps. So you could not drive any other power amp with that pre-amp section of the Kenwood.
If the preamp output were too low, you would not be able to turn up the music very loud.
In either case it might be noisy.
Also, if the input impedance of the power amp is too low, it could cause the preamp output to distort, but the input impedance of the MC250 is 200k Ohms, which should not be a problem.
What’s the output voltage spec on the Marantz? It should be around 2 or 3 volts or more. What is the output impedance of the Marantz? It should be much, much lower than the 200K Ohm input impedance of the MC250.
For comparison, the C27 output impedance spec is less than 1K Ohm and it is rated at 2.5 volts output (and goes up to 10 volts).
I assume you adjusted the input gain controls on the MC250 for best results.
