Rootpusher
Member
Does the MC250 have an on/off switch?
If not, what do you folks recommend for on/off operation?
Thanks
Thanks
The power switch in the C28 is part of the volume control switch. The extra current from the power amp plugged into the C28 could damage this switch. If this happens you would need to replace the volume/power switch on the C28 and it is difficult to find good replacement parts for this repair.I've heard this, too, but never an explanation for same.
What, if anything, is the science/engineering behind this concern about plugging the power amp into the pre's switched courtesy outlet? :scratch2:
Thanks.
This should work fine. In fact it will probably be better to plug the C28 into the powerstrip and use the powerstrip on/off switch instead of the C28 power switch, this will save much wear on the volume knob.This makes sense to me.
As a follow on question, then, is there a downside to plugging the MC250, the preamp, the tuner and the turntable into the same powerstrip?
I would think there would be no problem with the MC250 plugged into your C504. If it was a bigger amp I would be concerned. I have seen lights dim when turning on MC1021s, I would not want that power surge going through my preamp but I don't see a MC250 causing problems.My C504 pre has a push button on/off switch separate from its volume control.
With those control separated like that, would there still be a problem plugging my MC250 into the switched courtesy outlet on the back of the C504?
Does the risk of switch damage remain? Even if the C504 switch is easily replaceable, I'd just as soon not go down that road.
Thanks again!
I did not know that. Thanks for the info. :thmbsp:The c-28 has an additional switch on the top to switch the amplifier on and off. There are seperate green colored outlets on the back controled by this switch.
I don't see any problem with plugging in a MC250 into one of these switched outlets.
