MC2505 catastrophe
Have
Looks like you're keeping busy Celadon, that sounds like very thorough resto work. I will limit myself to caps for the moment I think, but you never know.
Good stuff!
"But you never know." :)
Well that's better than me -- at least you are listening to music...
Mighty fine lookin' there -- Benz :D
I remember replacing the .22 caps mounted to the term strip (your second pic) --a lonnng time ago.
So long ago that their was an electronics store that you could walk into and rack after rack of components -- those old guys knew their stuff too.
They mostly sold NTE -- but got you by in a fix.
Not much room to work at that term strip -- I remember saying a few words .... ahem.
Great to see your progress--
Myself I Haven't had much time to devote, as of late -- but that will change.
~C
Thanks Celadon, and you're right it was a pretty awkward space to remove and replace those .22s in the back... but taking my time and with a nice cuppa joe, it got done.
Hope you get yours running soon!
New batch of shiny new parts installed. 100uF electrolytics, 0.47uF and 0.22uF films. Now I'm waiting for the C33 can from CE, will take another few days. Can't wait to button it all back up!
Great job! How does it sound? If you have noisy gain pots, Faderlube can be spritzed in small opening where the yellow arrow is.
Yes, I was able to spray F5 in the gain pots this week and they are 99% noise free now. Out of caution I'm going to run the amp for a number of hours through the Minimus 7s before hooking up the NS-1000s, to ensure it's operating without issues. So far so good, it sounds surprisingly nice and clean even with those small speakers, but the true test will be when I have the NS connected. Very happy with the way things are going so far; could be my imagination but I think the amp sounds "crisper" (in a good way), if that's a thing. Also thanks again for recommending the Cornell Dubilier 0.47uF, they were a perfect fit size-wise and I was also able to select the correct 0.22 uF (same series).
Ok, I have what may seem a silly question, but is there an "optimal" setting for the gain controls? i.e. is it better to set them at the halfway mark, at max, etc.? I'm asking because there can be a slight unevenness in balance depending on how high I set them. I checked resistance at various levels between L and R, and the two pots aren't always giving identical readings between them depending on the level. This is expected I suppose given they are 50+ year old pots, but my OCD likes to have both set at the same level visually, which happens to be at the halfway mark on this amp. Is there any impact on SQ if I set the gains lower and the pre-amp volume higher, relatively speaking?
There shouldn't be. I'm not a fan of leaving a power amp sitting at full gain as transients, a bad cable, preamp issues, etc could cause full power output and damage a speaker - or the power amp. But then I'm running a MC2500. I learned this the hard way when, on my HB 300B amp, I was moving the preamp with the power on, and full gain on the 300B amp, and a signal cable worked a bit loose causing full power hum. Ruined a 300B and tore the spider in the speaker.
I do think Mac recommends that they be set at full gain, but do whatever suits your needs the best.
I think I may leave them at the halfway mark, I'm overly paranoid with the NS-1000s as good, used replacement tweeters are hard to find and mucho $$.
As is often the case, I might be overthinking this.
EDIT: btw, the amp sounds wonderful now that I've hooked up the NS. Listening to Wynton Marsalis right now...
Did the gain evenness of the two pots change after the recap?
My gain pots were slightly misaligned before and after the recap for equal sound output.
It might be normal unless there is an out of spec resistor somewhere. I tested my resistors and they were in spec.
I guess one way to rule out your preamp being the source of the imbalance it is to disconnect speaker cables and unplug your preamp from the amp. Then feed a mono test tone from a YouTube video directly into the amp from your phone (or other true mono test source) and measure the AC output at your speaker terminals with a volt meter and set the gain pots so the output is equal. Make sure the test tone doesn’t overdrive the amp input.
The pointer on the volume gain knobs may or may not line up visually with each other, A visual discrepancy of the knob pointer location may be a part of the design.
There’s also a process to calibrate the meter trim pots on the meter board which I haven’t mastered.
Maybe others here have tips on both the gain pots and meter trim pots.
Great suggestions! A few answers:
Monk: Did the gain evenness of the two pots change after the recap?
Benz: No, the L level has always beent a bit lower than R (based on gain knob position), even before the recap.
M: I guess one way to rule out your preamp being the source of the imbalance it is to disconnect speaker cables and unplug your preamp from the amp. Then feed a mono test tone from a YouTube video directly into the amp from your phone (or other true mono test source) and measure the AC output at your speaker terminals with a volt meter and set the gain pots so the output is equal. Make sure the test tone doesn’t overdrive the amp input.
B: Just did that. Voltage at the terminals matches what I hear. When the L-R gain pots are set the same visually, AC on the L channel is a bit lower than R. This also matches the resistance measurements I took from the pots earlier. I set the knobs so that voltage is equal between the channels at the terminals, and the L knob marking needs to be forward clockwise about 3 minutes (if this was a marking on a clock) when compared to the R knob.
M: There’s also a process to calibrate the meter trim pots on the meter board which I haven’t mastered.
B: Not sure if that's the correct way to calibrate, but what I did is adjust the L trim pot so the L VU matches the R VU when I set the gain knobs to the same voltage on both sides. That would obviously not help with the absolute accuracy of the VUs in terms of db, but my thinking is that this at least ensures that they are calibrated relative to each other. All of this assumes that my laptop's sound output is actually even out of both channels.
Yeah my volume gain knob pots needed to be slightly misaligned for equal sound output before and after the recap as well.
It might be perfectly normal for the amp design. Maybe @Celadon can check his….
It might be a function of the carbon tracks of each of the two gain pots not being 100% precisely matched with each other…
If so, whoever manufactured the two gain pots may be to blame.
If one is OCD, you could add a small amount of resistance to the channel that is louder to make the knobs equal…
Good points. Where does MAC say gain pots should be set to full gain?
It doesn't in the 2505 manual, but I'm pretty sure I've seen it elsewhere in other Mac manuals.
Here's an excerpt from my MC275CE manual, which accounts for different preamp outputs. 2/3 scale is for 2.5V output preamps. It seems balanced input is full gain. Not the same amp by any means, but somewhat communicates their strategy on the 275CE anyway.
INPUT
The MC275 has a two-position MODE Slide switch to permit the amplifier to be used as a 75 watt per channel stereo amplifier or a 150 watt mono amplifier. The amplifier also has a two position input slide switch to permit selection of unbalanced or balanced input connections. The unbalanced input sensitivity is 1 volt. Gain controls are provided for higher input levels. The controls are marked for 2.5 volt sensitivity for use with Mclntosh preamp equipment. The unbalanced input sensitivity is 2 volts fixed. For mono operation, the input signal is to be fed to the R (mono) input connectors.
I just did a quick review of the owners manual -- and as far as the gain controls -- It says to turn them up to "Desired listening level"
Me, I usually run mine at say 12:00 to 2:00 -- but then there are times, they get to full gain... I am running through a pretty high gain pre --
BTW Benz-- what pre are you using, and what is/are your sources... WE wanna know !!! :)
I have been playing refrigerator repair man today -- no refrigerator till parts get here, but less that $20 is way better than say a $250 service call...
I am still pulling everything together, and realize I have no cheap test speakers -- Not gonna run through my Klipschorns - as a trial.
Just gotta go find some cheap speakers that will make sound -- thirft store here I come ...
Benz this imbalance thing -- that has your OCD arise ... mine would be too --
You replaced stuff in the meter circuit --- recalibration may be in order -- uhh probly sending a 1k signal through etc --
Since you did all those additional caps -- and then you are going to do the CE cap, I would BEFORE doing any meter cal adjustments -- recheck your DC BAL
Heck even if not doing meter cal stuff I would recheck -- DC BAL
Just scrambled ramblings --as the refrigerator still has my frozen mind on defrost ...
Monk -- I have had issues with the volume control on a ratty C26 I have-- so Mcintosh sold me a new one -- imbalance as well. Known issue if I remember correct.
I posted a few pages ago that my gain pots were kinda funky -- did the contact cleaner/ faderlube thing - specifically, using as little chemical as possible --
Running them through their travel, lock to lock, -- before cleaning the readings on my meter were spotty across the travel --- after cleaning they felt smooth and readings were nice and dependable/ consistant. I did give the pots due exercise throught their travel maybe 30 times ...
How they sound -- time will tell. I had researched replacements and found something suitable....
My pre in this specific setup is an MX112, with a Yamaha CD player as source. But the slight imbalance has always been there no matter what the source. To your point, I will check everything again once the new C33 is installed. Will be curious to see if anything changes. Ultimately it's not the end of the world if it remains as is...
Benz -- The MX112 is one pretty piece of kit !!!
Ehh -- the imbalance will get figured out -- just watch and see :)
Waving the magical AK Wand over -- the unit....
Good day to you -- and thanks everybody -- this thread just keeps a moving along. :)
"Chock full o' Goodness"
Yes for sure, it also came with all the original documentation and is also in great condition. I'll do a bit of a show and tell when all is said and done. Will post when I get the C33, almost done!
Cheers
I think I figured out the issue. I pulled off both the gain knobs and looked at the back of each. The MAC factory inserted a flatted shaft crimped insert. On one of my two gain pots, the crimped metal insert was turned slightly so that the flatted portion wasn't true (i.e. perpendicular) with the notched position indicator marker.
I'm guessing that by using a pair of pliers and rotating that metal insert slightly, one could ensure that the knob position indicators align in perpendicularity with flatted portion of the gain shaft. Adjusting this way, (i.e. rotating the metal inserts as needed), both knob position indicators can be made to look "even" when observing the 2505 from the front.
