MC2505 catastrophe
I think I figured out the issue. I pulled off both the gain knobs and looked at the back of each. The MAC factory inserted a flatted shaft crimped insert. On one of my two gain pots, the crimped metal insert was turned slightly so that the flatted portion wasn't true (i.e. perpendicular) with the notched position indicator marker.
I'm guessing that by using a pair of pliers and rotating that metal insert slightly, one could ensure that the knob position indicators align in perpendicularity with flatted portion of the gain shaft. Adjusting this way, (i.e. rotating the metal inserts as needed), both knob position indicators can be made to look "even" when observing the 2505 from the front.
Monk --
That is the craziest thing-- awesome to have a guy like you around; who thinks outside the box .:banana:
All my knobs are off so let me find them and report.
Guess somebody got me with the glue ---
All the knobs from the front.
Monk -- I dunno -- just providing them as examples --
Along the road we go --
BTW -- wothout looking, the green sleeved diode/s and the diode splice below that on Benz unit --
Seems as though, I have no diodes at that point unless -- they are on the actual board -- I may be wrong -- but, they may be part of the compendium article -- referred to earlier ---
Nothing like that on my boards -- I don't think. more study needed on my behalf -- instead of taking others time--- but ...
May be a serial number (compendium) thing -- just thinking aloud --
IN your opinion --- you think my 2505-2 is newer than, Benz ---
wonder how much-- and the differences--- I know you compared date codes etc --
Just rambling today -- and trying to get things together -- bench is forefront, as I have a ton of other projects -- and expected answers for. (in conversation with a guy that does repro parts -- for other type machines).
Yeesh -- 4 :00 in the mornin' -- if only I was a blues singer ...
MY best
Celadon
Are all of your inserts aligned correctly? If not, you'd have to soak those in some type of solution to loosen up the glue and rotate the insert.
Monk--
I am certain all of my inserts were NEVER inserted correctly -- just ask the doctors....
As far as my amp -- I dunno -- yet to be determined.....
:D
Another great find and idea, once I'm done replacing C33 and after another round of adjustments I'll see if I can get the knob off, it's on there pretty tight.
OH **** -- Benz
You know
You spoke of the spoon thing AND NOT TO USE IT on the glass ... you know that ---
Uhh get someone elses verification procedure--- before trying to pull the knobs -- mine were easy to pull, but VALUE that damn original glass!
i mean -- i HAVE new glass here from McIntosh -- thought I WOULD REPLACE THE FRONT --
AS i have said before -- the gold teal original glass is much more impressive (to me) .
I have both, and the repro sits in the box -- only slight repairs to the original glass-- maybe I do, maybe not ...
MY best
Celadon
Check date codes printed on your original output transistors and compare to dates on resistors and capacitors. This will help triangulate approximate production timeframe.
OK Monk --
you are the king of date codes --- LOL
BUT, YES --- will do -- thanks again --- not a priority, but yes thank you ;)
The later Mac knobs have a splined plastic insert. Sometimes when you pull a knob the splined insert stays on the shaft. Anyhow you can adjust the pointer location by pulling the insert and rotating it to the proper orientation within the splines. Not sure about those aluminum knobs.
OH **** -- Benz
You know
Definitely won't use spoons on the glass, that would be a very bad idea. Fyi, the front glass panel on my amp isn't the original one, the 1996 invoice shows that it was replaced. Looks great to me, still. It retains the "metallic" (a bit like metal flake) look of the original lettering, but with a slightly green tinge vs. gold.
Interesting that the 1996 repair shop calls it custom made. Was the 1996 glass from the McIntosh factory parts dept? Or is it aftermarket glass?
By the way, the replacement glass the MAC factory sells these days hardly lets any light through vs the originals from back in the day. They changed the production method. The new method prevents bubbling from occurring, but it only seems to let through a small fraction of the light. The text on the glass ends up being very dim on the new glass if you use the original incandescent bulbs. You have to use Quasar LEDs from Comet Pinball to punch a decent amount of light through the modern glass.
I'm sure it's original Mac glass, it's flawless and looks to be the same quality as the original glass on my MX112. The lettering is actually quite bright so they must have changed the process sometime after 1996(?).
That repair shop in 1996 added a nice bit of markup on the glass. $200 back in the mid 90s is probably the inflation adjust equivalent of close to $400 now.
Benz - it also looks like you got 2 new potentiometers -- w/ what looks like McIntosh part numbers -- can't tell from the pic, but....
see if that number correlates with the part number for the gain pots -- in the SM.
AND -- you got new input jacks !!! I have been wondering what to do about mine - they are the weak link in my amp, but currently using Klei Absolute Harmony RCA's on the Interconnect i am using, and they grab nicely.....
I saw that too Monk!! Yeesh-- last year or so I think I paid ~$150 for the new style glass direct from McIntosh.
You're right. Cool that they still had those pots in the 90s. Are those replacement MAC pots even available now from the parts dept?
Benz can you post photos of your input jacks?
I wonder if McIntosh does have those gain pots -- in the column marked Brand (as clearly as I read, from the receipt)MACP would tend to make me think MAcPARTS --
The input jacks are Altron --- I did a fast search and nothing came up ----
I am really hesitant to mess with my input jacks -- I just dunno yet, lets see what Benz pair looks like ....
The invoice shows p/n 134210. According to the SM, the gain pots are p/n 134-187. The trim pots on the input board and the meter board are p/n 134-120. Based on that, and the low price charged on the 1996 invoice ($24.70CAD), I'd be inclined to think that it's for 2 trim pots and that they somehow messed up the p/n by inverting the "2" and the "1". Just a guess, but I don't see an original Mac gain pot costing only $12CAD even in 1996. To be honest, all 4 trim pots look pretty original to me so it may have been another case of "creative" invoicing, like they did with the 2 extra caps that never got installed.
