MCD7008 converted to LED
hadrian333
This MCD7008 now has no incandescent lamps. It is backlit with 2 Northridge Electronics 12VAC bipin LED's. No modification necessary but the bipin LED's have to be soldered in place like the original lamps.
I know this is an older thread.... I am looking to replace 2 bulbs on my MCD7008 with LEDs and I am striking out on where to find some compatible replacements. Id like for this to be the last time these are replaced :)
This MCD7008 now has no incandescent lamps. It is backlit with 2 Northridge Electronics 12VAC bipin LED's. No , never !! this is ordinary incandescent lamps no LED
I am looking to replace 2 bulbs on my MCD7008 with LEDs and I am striking out on where to find some compatible replacements. no , don't do that , I strongly recommend you to use original incandescent lamps
replacing lamp by LED is stupid just because some guy decide to do this to avoid to have to replace lamps . Lamp life time is long , vey long and it is not a reason to use LED
