McIntosh MC275 MK VI Clone
Interesting clone. It would have been far more intriguing if they had used point-to-point wiring with tag boards like the original and the 1993 reissue. The Chinese are certainly capable of doing decent traditional wiring, as Primaluna and others have demonstrated...
We have that one too...
I'm not gonna post a link, but there's actually a McIntosh branded MC275 clone on AliExpress. Even the tubes are branded McIntosh. Crazy. The main PCB appears to be a green one like McIntosh uses...
Currently at 60hrs....Time to burn-in the New Tubes. The EH KT-88's are nice sounding tubes after 25+hrs, since I have used GL KT88's let's see what
these can do for this clone.
Tubes:
4 - GOLD LION KT88
4 - MULLARD CV4024 / 12AT7
3 - TUNG-SOL 12AX7 / ECC803-S GOLD PIN
It's amazing to me what we will and will not tolerate. The maker of this amplifier profits at the expense of another's hard work. In addition, every one they sell comes at the expense of a real one being sold.
By the same token, are we OK with others profiting from our own hard work, ideas, etc? Or is that where we draw the line?
Just wondering if you have a job we are paid by the hour? If so someone’s making a profit off of your work. That’s called capitalism. Have a nice day.
Wages are the reward for working.
Profits are due to investors whose capital investment is at risk.
Workers are not investors.
Being the business/economics expert that you are, I’m sure you’re well aware of this but I thought I’d point it out all the same.
80hrs and all is well. Everything is Sounding and Running well. I have been using a Temp Gun to meter the Tubes and Transformers (10-14hrs of running per day). Tubes at 175-195°F, Power Input Trans 90-98°F, 2 Output Trans 75-80°F (Temp Meter at rear of unit). I just got back from Best Buy and a MC-275 was running and I whipped it out for a Temp check..:naughty:...Tubes at 235 - 242°F, Output Trans 75°F and Power Input Trans 95°F (Temp Meter at rear of unit). I know the Manager and no one approach me...it was 12:00pm so maybe Lunch? The MC-275 (Real) is hooked up with MartinLogan - Impression Dual 8" (which sounds Bloated).
I worked for a manufacturer who had their products ripped off by Chinese copycat manufacturers all the time. It was a constant battle. We would find them, the Chinese authorities would shut them down. They would pop up again.
It’s not that the design is no longer patented, or that the price is really different.
It’s that somebody is trading on your company’s good name and reputation and profiting by it.
You can’t justify it by saying it’s a different market or that you wouldn’t buy the original, as the moderators and a lot of posters have already done.
Not everyone will share my sentiment and that’s perfectly fine. I just thought the group would like to hear it from a manufacturer’s point of view.
I’d also add that it is a bad business practice for McIntosh and Audio Clasics to sell replacement logos without some sort of proof of ownership.
Clone temps are too low, op tubes should be showing more heat if not biased off.
Are they biased class"B"?
The reading is off from the Plate...again using a Laser to read the temperature. Now the EH KT-88's had a reading of 200 - 245°F. The unit is Self biased.
I use the same technique on my amps, the defective nonconducting 6CA7s give me those temps. Good tubes add another 150-200F.
Getting temp readings through the glass is hit and miss. I've gotten a range of easily 100F just moving it around slightly, depending what it reflects from. A power transformer that doesn't break 100F in operation I'd consider to be a good sign though. Its not being overworked.
Mac amps do run the tubes relatively easy though, so if this biases the same I can believe they aren't really chugging out a lot of heat. Per the values I found on an MC275 schematic, it looks like the tubes are running right around 16 watts plate dissipation on a tube rated for 35.
I started two successful businesses from scratch. Never stole a single idea from another person in the process.
But, thank you for the education on capitalism.
How's this for irony.....a Marantz clone built for and named after the venerable McIntosh retailer, Audio Classics, in Vestal NY. https://www.audioclassics.com/detail?detail=9B&nav=cat Some much for being loyal to the brand of Marantz...:thumbsdown::no:
So you're ok with that?
100%.
VAC made Marantz reissues/copies of the 7,8b and 9 "for" Marantz awhile back. Then they made the "9b" for AC.
Doesn't say Marantz anywhere on it.
Marantz never made a 9b.
The 9b is a stereo amp, the 9's were mono only.
Not even close as to the circuit topographies.
I don't see 'rip off' about anything re the 9b. Yes, it resembles a 9 but that's about it.
Slight difference: Today's Marantz is in name only while McIntosh continues to exist largely unchanged from its original form. Secondly, the MC275 Mk VI is a current McIntosh product while Marantz 9/9B isn't.
