richardg0n
First, it looks like you can repair that choke, see the circled area in the pic below, it appears that wire has broken. You can pull off a half turn of wire from the choke so you can re-solder it, or bridge it with a short piece to fix it.
Second, man I wish I knew you had a signal tracer - woulda made some of this easier!
Third, I think the Sencore (if working) would be best since it does stereo. The HP would be excellent for the front end and IF, but not much help to align the MPX. The HP 8656A is a beast of a sig gen, with absolutely top-notch quality. But there are downsides to it, namely the attenuator can get funky, and complexity of repairing it if it craps out. I'd offer the guy a hundred and if so, that'll get you close and you'll have something that will serve you well for years.
Fourth, bummer that the LO isn't working, apparently.
Last, the ICs seem to be drawing a bit more current than expected. You might need to round up a couple of CA3012s. Be advised (as I mentioned) these are a giant PITA to replace, because of the ten pins in a circle. Getting all the pins aligned into the holes is no fun. To remove them, I'd just clip all the leads (but note beforehand where the tab on the IC case is siutated), then pull the leads one by one. If you have a good vacuum desolder station that'll make short work of it though.
I'm going to solder the choke per your recommendation.
Regarding signal tracer, I recently purchased but was sitting in the shipping box until a week ago. Out of sight out of mind. Sorry about that.
Thank you for the buying advice. I purchased a "Mint" SG165 on eBay but suspect it will need to be recapped and calibrated. I was not able to meet with seller of HP 8656A and instead opted for a newer signal generator also purchased on eBay. A.B.O from Japan(see attached), it was a unit used at the Pioneer test labs in Ohio. I opted for this signal generator because it's newer and hopefully less prone to repairs. My plan is to use this with the SG165's MPX if need be. I think I'm done buying test gear for now....LOL.
I also found NOS RCA CA3012's on eBay and will install them when they arrive.
I will circle back and check in once the CA3012's are installed. Thank you for you help
