I have several SAMS manuals in front of me at the moment and I'm looking over the power amp sections
3207 is a simple 5 transistor per channel(7 if you count darlingtons as 2). It does not have a differential input or a bias adjustment according to the schematic. It is a bootstrap design with darlington outputs. No speaker protection.
3230 has 9 transistors(11 counting darlingtons). It has a differential input pair with a resistor/capacitor voltage tail. Resistor/transistor set current VA stage with typical bias setting transistor. It has darlington outputs with a pair of current limiting transistors on the emitter resistors. Uses fuses for speaker protection.
3233 and 3235 are the same except the transformer voltage is higher on the 3235. They have 8 transistors per channel(or 9 if counting bias darlington). It has a differential input with a zener/capacitor voltage tail. And a bootstrap VA stage with typical transistor bias setting. It uses a typical emitter-follower driver and output stage with 1 pair of 2N2955/2N3055 per channel. The heat-sink includes the chassis and has thermal grease between the flange. Uses fuses for speaker protection
3835 has 7 transistors. It is the same basic design as the 3233 & 3235. It has a differential input with a zener/capacitor voltage tail. And a bootstrap VA stage. Except it uses a diode and potentiometer for bias control. That is worse for temperature compensation. Has 1 pair of output transistors and uses a relay for speaker protection.
3237 has 11 transistors. It has a differential transistor input with a diode/transistor current source tail and a diode/transistor current mirror on the collector side. It then goes to a diode/transistor current source paired VA stage and typical bias control and emitter-follower in drivers and output stage. Has 1 pair of output transistors and fuses for speaker protection.
3245-00 has 11 transistors per channel(12 with bias darlington). It has a differential pair input with zener/capacitor controlled voltage. It goes from there to a diode/transistor current sourced VA stage with typical bias control. It is then a typical emitter-follower driver and output stage with 1 pair of MJ1015/MJ15016 and a pair of current protection transistors driven from the emitter resistors. Runs on +/-38.5v. It uses a relay for speaker protection.
3245-10 has 12 transistors per channel(13 with bias darlington). It has a differential pair input with zener/capacitor controlled voltage. It adds a transistor to the circuit in the 3245-00 to make it a differential-current mirror VA stage with typical bias control. Then on to a typical emitter-follower driver and output stage with 1 pair of MJ1015/MJ15016 and a pair of current protection transistors driven from the emitter resistors. Runs on +/-42.5v. Uses circuit breakers for speaker protection.
3253 has 7 transistors. It is basically the same as the 3835 with higher wattage. It uses a differential input pair with a zener/capacitor controlled tail. It uses a bootstrap designed VA stage and typical emitter-follower driver and output stage. It uses 1 pair of 2SB618/2SD558 output transistors and has relay speaker protection.
3260 has 15 transistors. It uses a FET differential input and zener/capacitor voltage tail with DC offset potentiometer. It then goes to a second differential pair made from bipolar junction transistors. Then to a third differential pair for the voltage amp stage with a diode/transistor controlled current source. Uses a diode and potentiometer for bias control. The path then goes to a emitter-follower driver and output stage. It has two pairs of staggered current protection transistors on the output emitter resistors. It has 1 pair of output transistors and uses a relay for speaker protection.
3860 has 7 transistors and an IC. It uses an IC for input and voltage amp stage. It then goes into a emitter-follower driver stage with transistor/potentiometer bias control. Then to another emitter driver stage with thermistor bias protection and into a single transistor pair output. It uses relay speaker protection.
3275 has 11 transistors (uses 2 pair of outputs). It is almost the same design as the 3245 except it uses a resistor/capacitor current tail on the input pair. This is a step down below zener controlled source. Both are worse than a transistor current source. Also has diodes instead of transistor for bias control(inferior temperature compensation), and does not have a pair of transistors to control output current. It uses 2 pairs of 2SB618/2SD588 output transistors. It uses relay speaker protection.
3285 has 23 transistors. It uses a FET differential pair with a zener/transistor current tail and a pair of transistors for current mirror legs. It then goes to a differential pair with resistors for legs and tail. Then on to a differential pair VA stage with diode/transistor current mirror. The output side of the last differential stage has one transistor cascaded with it for linearizion, voltage handling, and has a zener to keep it from overload. It uses two diodes and a potentiometer for bias. Then to two emitter-follower driver and one output stages. The second higher current driver stage has an adjustable current mirror between them and the base resistors for the output.(unusual) It also has two pairs of cascaded transistors driven from the output emitter resistors and a thermistor for current protection with thermal tracking. There are parallel resistor/capacitors on every base of the drivers and output. It uses relay speaker protection.
3125 has 22 transistors. It has a FET differential input pair with zener/capacitor collector legs and a diode/transistor current source tail. Tail has DC offset potentiometer. Path then goes to a bipolar junction transistor differential pair with resistors for legs and tail. This goes to a third differential pair VA stage with a transistor/transistor current mirror. It uses a pair of diodes and a potentiometer for bias control and a transistor cascaded with one of the last differential pair and appears for linearizion and voltage handling and has a couple of diodes to keep it from overload. Then it has two emitter-follower driver stages and one output stage of a single pair of transistors. It uses no capacitors in the base paths and no resistors at all on the second driver bases. It has six transistors driven from the output emitter resistors and are used for current protection. Two pairs are cascaded into the other pair and one has a thermistor in the base circuit. It appears they might have two different cut rates and thermal compensation on one. The one with thermistor cuts right at the max power level, hard cut. The other pair cuts at about 1/3 power, but needs to charge a capacitor first and average power, or soft cut. The 3285 and 3125 are similar but I would say the 3285 has a better input differential stage, but everything a little worse than the 3125 after that.
These are some of the basic attributes I noticed. There are many small details as well. They all have different resistor and capacitor sizes even if the schematic design is basically the same. Dominant pole capacitor roll-off, negative feedback curve, gain, and values that effect slew rate could all be examined further. I'm open to schematics or comments to add.
